Strange signal problems.
Nissan86
Hey all,
I've been struggling to find the ghost in my electrical system for the last couple days and am looking for some insight. My turn signal lights haven't been working lately and neither have my hazards. I replaced my signal bulbs and the signals worked for a little while but then crapped out again. There also seems to be a weird correlation between my hazards and brake lights. If I turn my hazards on my brake lights quit working but will start again if I cycle the hazards again. My hazards will also only flash on the right side if I signal right but it doesn't respond in any way to the left signal.
Pretty much I'm mystified. Please enlighten me if you can.
longtooth
Car: 89 d21 HB
If it was a old gm car I would say your turn signal switch is failing. Have you tried a new flasher relay?
sweetride2go
Car: 93 Nissan Hardbody (D21 4x4) w/ VG30dett
74 Datsun 260Z SBC and 6speed
Try cleaning grounds... Bad or weak grounds will create all sorts of electrical phenomenon.
Good luck
Q451990
Do you have trailer light wiring? If so, the problem is almost always somewhere in the wiring there...
Heath
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
If your hazard switch is malfunctioning, it will cause the turn signals to fail to function. Maybe disassemble it carefully and ensure the contacts still look okay inside.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I've seen the turn signals switches burn up in these trucks making for all kinds of lighting nonsense. Hazard and/or T/s switches are worth looking into.
