blaruffa »
https://forums.nicoclub.com/blaruffa-u78078.html
Sun Aug 30, 2009 5:48 pm
Have a few strange things happening with our car.1. When you lock the doors it no longer beeps, yes I check and it is set for horn chirp on lock2. The Down Shift button on the gear selector is not selecting a gear when in L and push the button can't get the car into 2, same when in D can get the overdrive off3. Drivers Seat stopped sliding back on exit, yes, I check it is programmed to slide on exit. I did unplug the seat ECU and that did seem to fix the problem.
It is like the Computer is hosed and needs to be rebooted.
How long should I leave the battery disconnected to totally get the ECU's to forget any memory and go back to default.
Any thoughts would be helpful.
