szhosain wrote:In a DOS command prompt window, try entering:
"dir c:\windows\system32\sfc.exe" and see if this file exists. If not, then this option is not available to you, unfortunately, unless you can find an XP install disk to load it from as that image represents.
Well I figured out that I do indeed have some HDD issues and got my storage devices (All of them) checked out thoroughly with Spinrite. BUT I still need some help from you guys, I am not sure how to interpret the results of my (12+ hrs worth of) Spinrite tests.
Help a bratha out?
Is any of this information useful interms of figureing out the status of my drive or is this normal stuff.
These are all errors I recieved from "Item 2 on drive 0". It is a partition on my drive used for "GoBack", which is a Norton recovery software thing... I think.Any thoughts on this? More on this in my video.
http://www.youtube.com/watch?v=EBlD71UWsVkI was messing with my Video software and decided to add music and effects, ignore them.
The rest are results of my HDDs "performance test" - the drive/partition being tested is highlighted in purpleAnything going on here? Anything that raises eyebrows or warning signs? My add on slave drive is just a 60GB External USB HDD I have.
Also before I changed my Boot sequence back to normal (I changed it because I was failing to get Spinrite to run but the issue was not related to the boot sequence) I got this error. Anyone know what it means?
http://img64.imageshack.us/img64/8005/1002753.jpg
Thank you in advance for any responces
Modified by RCA at 7:32 AM 12/27/2009
