Hussain wrote:not to dis mehdi or anything but he didnt know what he was talking about... ive track tested my car and have numbers to show that it is actually faster... i ran a 14.4 stock, 14.2 with exhaust, and a 13.9 with no muffler and all were at the same track with similar weather conditions. mehdi did say its not the best thing for daily driving and i agree with that because you'll have no back pressure and you'll lose a lot of low end power but up high it will pull much harder and scream like crazy..... thats why i got a electronic exhaust cut-out. so i can chill and drive normal and then hit the switch and have my car like its straight piped.
thing is, both 2.5s and 3.5se have MORE then enough power for daily driving if its stock or straight piped. only difference is that straight piped is faster for racing.
A word of caution while using your exhaust cut-out.
Actually three words: Carbon Monoxide Poisoning.
Since the exhaust is not exiting at the rear of the car, exhaust fumes may enter the interior, and poison you and your passengers.
Automotive engines emit several types of pollutants, including carbon monoxide.
What is carbon monoxide? Carbon monoxide (CO) is a colorless, odorless, poisonous gas. It is a product of incomplete burning of hydrocarbon-based fuels, and is a by product of the internal combustion engine.
Why is Carbon Monoxide Dangerous?
When carbon monoxide is inhaled, it passes from the lungs into the hemoglobin molecules of red blood cells. This causes interference with the oxygen transport and gas exchange abilities of the red blood cells.The result is that the body becomes oxygen-starved, which can result in tissue damage and death. Low levels of carbon monoxide poisoning cause symptoms similar to those of the flu or a cold, including shortness of breath on mild exertion, mild headaches, and nausea. Higher levels of poisoning lead to dizziness, mental confusion, severe headaches, nausea, and fainting on mild exertion. Ultimately, carbon monoxide poisoning can result in unconsciousness, permanent brain damage, and death.
To be safe, keep your windows open while driving with your exhaust cut-out open.
To really be safe, consider installing one of these in the interior of your car:
Carbon Monoxide detector http://www.firstalertstore.com...=1227
Be safe out there!
