Yes!1SlowCA18DET wrote:is it possible to run 264 cams on the stock valve train?
Yes!originalsin wrote:reliably??
The cams can be used in either configuration. You can take a 272 camshaft with a 9mm lift and use on the stock CA's drive train. Anything above this and you will need to have the head heavily machined for camshaft clearance.biosehnsucht wrote:as long as the cams are meant for hydraulic lifters and not solid ones :P
