Stillen Pulley install, bolt stuck, wtf??
All things Altima Coupe.
RobPaulson
Car: 2013 Subaru WRX
So I am trying to install the stillen pulley on my 3.5, and the OEM pulley bolt wont come off!!! I have used an electric and air impact wrench with no luck, I actually broke one of my 19mm sockets =/
WTF Do I do to get this thing off!?!?
RobPaulson
I tried using a breaker bar too and the motor just turns, no idea how to get this thing off...
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
i could be wrong but i might have seen dangeris stick a screw driver into the slots to stop it from spinning.
Did you check out his tutorial?
charliejj
Car: 2008 altima coupe 3.5 MT dark slate
I had the same problem installing my pulley. I took off the belt before removing the bolt and it wouldnt come off, after a while messing with it i installed the oem belt again then tried removing the bolt. It came rite off . I also was using a cordless impact gun. The whole process took about half hr to install. maybe this will help
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Yeah not sure what problems you guys are running into but after I took off the belt, I was able to take off the bold with an impact wrench. No problems what so ever.
Charliejj's method will work just as well. Good luck guys
Ferguson
Car: 09 3.5 SE Coupe
17 370Z Nismo
RobPaulson wrote:I tried using a breaker bar too and the motor just turns, no idea how to get this thing off...
I haven't done mine yet because the weather hasn't been good enough.
But if you remove the starter motor you can jam the flywheel so it can't turn. A bar and an impact socket should then easily get the bolt off.
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Honestly, I don't think you need to remove anything but the items I specified in my install thread. When I took off the service panel, a 19MM 6 point socket took that bolt right off. Maybe it was torque down a little more than usual from the factory.
Ferguson
17 370Z Nismo
Well, certainly worth trying before pulling off the starter! You had no problem retorquing the bolt after installation?
RobPaulson
Whys this gota be so difficult ... i mean really, REALLY!? Look what this BTCH did to my socket!!!
marlin29311
Car: 2008 Infiniti G35x
Crappy Chinese sockets...
RobPaulson
marlin29311 wrote:Crappy Chinese sockets...
ya i admit i dont have the absolute best parts ... but cmon, really?? gota take it to my uncles shop and use some pro-grade tools ... not wasting my time jacking up and taking off the wheel again like this ... ggrrrr
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Geeze man, Not sure why you're having so much problems. the socket I use were Snap On so no problems there. Worst come to worst, bring it to a garage. Should only be 1/2 hour tops to do the job.
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
go
RobPaulson wrote:Whys this gota be so difficult ... i mean really, REALLY!? Look what this BTCH did to my socket!!!
get some craftsman tools bc this will never happen n if it does you get new ones for free....lifetime guarantee email me if you do bc i might be able to get you 10% off [email protected]
gearhead05
Car: 2008 Nissan Altima Coupe 3.5 SE
I guess I'm gonna bring the post back from the dead; did you ever manage to get your pulley on? I just got done trying and that freaking bolt would not come off. I had the same problem. Breaker bar, impact wrench, nothing would break that stupid bolt loose. I tried jamming it with a screwdriver to stop the pulley from turning as well but that didn't do a thing. I don't know what else to try.
legend_217
Car: 08 Altima Coupe 3.5 black
Do not take out your stock belt when remove the bolt.
RobPaulson
legend_217 wrote:Do not take out your stock belt when remove the bolt.
tried that
and yes, i did try this again, i also took a blowtorch to it for a while to break down some of the lock tight, no dice.
need a badass impact, proly gona end up paying someone to do it.
altima5507
same thing happened to me theres a product called pb blaster sorta like wd40 but stronger spray that behind the pulley(it comes with little straw PB blaster) let it soak in and in 5 mins the bolt comes right out
bravey_z12
Car: 2.5 6spds A/C [azure blue]
very nice infoi getting installed next monthsuch a useful thread
JIBRIL4life
Car: 2.5s 6MT Altima Coupe
yeah any type of penetrating oil. dont worry about over using it. clean it off afterwards.
wd40 is bad joo joo .
penetrating oil is where it is at.
3ugene
Car: 2008 Altima Sedan 3.5SL
i started the engine when it was stuck. got it off in a jiff.
strangebh73
Car: atlima coupe 2.5s
use an impact socket and a breaker bar. secure it against the frame or the ground and bump the engine over, problem solved, this method has been used by technicians for over 50 years. to tighten it on the other hand will be interesting, make sure you have a torque wrench.
Jose3.5
Car: 2007 Nissan Altima SE 3.5
Did anyone ever post a review for the pulley and what it does for the car?
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
ofcourse there have been reviews!Search Query: "Stillen Pulley" in titles yields Dangeris' install thread with comments.
http://forums.altimas.org/zerothread?id=405345
Jose3.5
Yeah I just did that and found a few. I was searching with other terms and it couldn't find anything.
