Just saw on the other thread that they're almost done with it.bina12834 wrote:dont forget about us 2.5ers!!!!!!
Bro, that's all you. However, I'm pretty sure they will use their own 3.5 for the install Would be interesting to see if these would work with my turbo. We didn't change anything about the headers, just past the precats'. So this might workrjdmmfl1 wrote:
count me in for six months... but since Blake has a turbo, if he can't use these Stillen headers, if you need a 3.5, holla at me!
Not trying to steal your sponsorship at ll Blake, again, I'[m only throwing this out there because I don't know if this will work on your turbo setup... otherwise, we all know the Stillen pecking order
This would be about 10-12 hours of labor performed by a competent mechanic with the right tools and experience.GryStrm wrote:10-12 hours by an advanced mechanic...using all tools that a full garage would?..ie lift...air tools...engine hoists..(incase the motor has to be lifted)?
or 10-12 hours by a semi knowledgable DYI'r with the compliment of an average to above average car person?...floor jacks, stands, and if your mehdi...a 12v impact wrench that you can plug into your cig lighter?
im with the photoshop guru...1600 for 20 hp?....once again...my vote is to put that 1600 in the turbo bank...
on paper arent you supposed to get that gain with an intake and cat back exhuast...that being said....half the cost and certainly half the labor..same gain or close enough to negate the extra $$?
yeh 1000 is alot for labor thoughFGFCacoupe wrote:I am a definate buyer, if the headers were available for purchase today I would buy them today. This is good news and I am very excited about this for it is something that I have been waiting to have on my car for a longtime now. 20 horses is a lot of power to be gained on naturally aspirated V6. A Lot
most high flow cats if not all are illegal on the street. what i suggest are electronic exhaust cut-outs. so one minute your driving along like normal and then you hit a switch or turn a nob and all of a sudden your exhaust gets shut off and a 2nd route is opened up that has no cats, no muffler, nothing hooked up to it. it's pretty much the same concept as me unbolting the muffler right after the cats. i got a 13.912 (almost a 13.8) by just unbolting the muffler AFTER the cats. just think of what you could run with headers and 2 electronic exhaust cut-outs (one after each header..... before all 3 cats). with headers and electronic exhaust cut-outs on a STOCK 3.5se CVT i'd expect around a 13.6 in the 1/4 mile. thats my estimate without getting intake, tune, and other stuff.Altimus_Maximus wrote:What about the addition of high flow cats? Seems like the headers are nice, but without highflow cats, aren't you just opening up the flow only to squeeze it back into a chokepoint?
I 2nd that motion.... Unless Stillen would so the whole thingLoop wrote:I would rather be interested in HFC's or TP's and a y-pipe than headers. A y-pipe you can DIY. The HFC's or TP's would be cheaper in labor comparing to headers.
Yeah, but that goes with the same for headers. They need to be CARB legal as well and that may take months or years to do so. I believe your 350z headers for example are not carb legal yet(could be wrong). So in this case it isn't worth the trouble specially for labor cost or man hours. This is why I prefer HFC's/TP's because they are easier to install or remove if you were to get a ref ticket. I still would like to see a y-pipe done too, they are easy install and you don't need to worry about inspections.kyle@stillen wrote:Ok, there are a few good topics that have been mentioned in this thread...I will try to address as many as I can, if I miss your question or suggestion I apologize...I will review the thread again to make sure I answered everything.
HFC's/Test pipes- High flow cats are not street legal in a state that performs a visual inspection. If your state only performs a sniffer test then you will more than likely pass. However, if your state does a visual test you will fail. It is against FEDERAL law to modify/replace/remove your catalytic converter unless it has been damaged/worn out/or your car exceeds a certain amount of miles...I want to say 100,000 miles. Then, it is only legal to replace your catalytic converter with an O.E. replacement. If we do produce high flow cats for the car they will be stamped with a badge saying "these parts are intended for off-road use only and are not intended for use on highways."
Headers & HFC combo's...I can't say exactly what the combination will be as I do not know yet. This thread is simply to gauge interest. In reality, headers can gain around 20 HP at the rear wheels without changing to a high-flow cat or race pipe setup. We have done this before on many vehicles and it works...If the kit is to include HFC's and Headers then the price will be more likely around 800-1,000.00 (in parts.)..See the 350Z and G35 prices as an example...
Installation- My $1,000.00 additional labor rate was simply a suggestion of something to consider. There will be those of us who can install the headers ourselves and won't have to go to a shop. However I think the majority of Altima owner's will be having the headers installed by a professional shop...In which case they can expect to pay around $1,000.00 labor...
