Sgt »
https://forums.nicoclub.com/sgt-u96869.html
Wed Feb 10, 2010 9:42 pm
How did you determine one bank is richer than the other?
Perhaps you aren't getting proper spark in a cylinder. How are the spark plugs?
What I would do, is determine which cylinder is rich by examining the spark plugs. Test the wire that plugs into the coil packs with a timing light to see that there is a proper signal getting through (don't check the timing this way, just use the light to see that it sparks). If any do not spark or spark properly, we likely have a PTU issue. If you find no issues here, unplug the wire going to the coil pack on the bad cylinder and see if it dramatically effects the idle (do while running). If it does not effect the idle, you have a bad coil pack. If it does, the issue is else where (not ignition).
