Sticky accelerator?
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
pistolkeith
Car: 1985 Nissan King Cab 720
My fellow 720 lovers,
I have a problem with my 85 KC that when i accelerate off and clutch in to change gears the revs seem to have a delay in them to come back to idle? like the accelerator is sticking? could it be that the idle spring is worn or the accelerator spring is worn? I dont know a whole lot about the engine sides of things so any help you can offer would be greatly appreciated :)
PEZi
Go under the hood, and play with the throttle by hand. Take a visual look to see exactly what is happening ie: worn spring etc. If everything is returning properly, my guess would be something carb related causing and excess of fuel to be left burnt after you let off.
pistolkeith
perfect. its simple answers like that that my brain just doesnt quite think of. I'm learning! I'm learning! haha. thanks so much, will try it tomorrow and report back.
rocky1234
ck bcdd on drivers side of carb remove rubber ....blade screw driver adjustment
mattthruwalkin
Car: 1984 nissan 720 4x4
get a can of carb and choke cleaner , remove breather , filter and cover and spray carb cleaner all over the linkages and springs and then spray in the carb to clean it out also , i has same problem with tacky gas pedal . hope this helps
Return to “Datsun 720”
