ProteanCarnage »
https://forums.nicoclub.com/proteancarnage-u193591.html
Sat Nov 12, 2011 6:13 am
Had to dremel out the sides of the stereo unit opening so it would fit. The stock radio was much much smaller then the sony i was installing. Should have taken pictures. Anyways after some searching i found an adapter at walmart to simplify things a little bit, got all that together, and with some tight squeezing got it all packed in there. Actually its not even screwed in. The fit is perfect so it just sits in there happy as can be. Front two speakers and head unit all attached to stock adapter.
When i find a way to fit some 6x9's and subs in there, i will have to connect them to an amp for sure.
