rdsworks »
https://forums.nicoclub.com/rdsworks-u91907.html
Sat Apr 12, 2008 2:03 pm
Hey,
I just installed my system (deck, amp, sub) and had a similar problem. if you look directly down from where the deck goes you can see some metal... if you get a bolt and nut and attach the deck's ground to it, your problem should be solved.
it looks like a "L" with some holes on it. hope that helps
btw, I don't have my attenta hooked up and everything (except radio) works
