VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sun Jul 10, 2022 6:05 pm
It's possible, but Md is right, you have to be extremely careful to match up pin positions on the bags to pin positions on the bag brain. Nissan also uses a resistor-divider array for most of their s/w buttons, so if the arrangement is different or if there are more or less buttons, the analog voltages coming out of the array won't be correct. That will mean things like pushing the "dial phone" button in order to turn up the radio volume, etc. The first thing to do if you're serious is pull out the WD's and map the connectors for the clocksprings on both donor and recipient. Once you know whether the buttons are likely to match up, then you can start shuffling whatever pins need to be shuffled to make everything else work.
