VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sun Jul 03, 2022 4:05 pm
It's unusual for an ESCL to cause the car to die, usually you shut them off and they fail to wake up. On a gen4 the symptoms are a yellow key icon in the cluster, a "Press Brake" message in the info display, and no other response from the Start Button. If any other lamps are lit in the cluster, the key icon isn't yellow, or the Start Button elicits any response whatsoever, then the ESCL isn't causing your issue.
