static sound when on gas?!?! WTF
Ghut300zx
Car: 1995 300zx N/A
alright, so i recently noticed when my car is running and i press the gas (even just barely) i here a hissing/static sound that sounds like it could be coming from the rear speakers. It is vary faint and only happens when im on the gas. as soon as i release my foot from the gas petal it stops. i have a sub and amp installed but the speakers are stock. it happens whether the radio is on or off. is it possible that its my fuel pump im hearing and does anyone else have this problem?
zxFarside
Car: 94 300zx TT (sold)
03 Suburban 5.3
00 BMW 323
Dose your car smell like gas? lol
rjmancia
Car: 1993 Nissan 300Zx t top
hey i hear that static sound too! and i drown in gas fumes in the morning... it only does it in the morning when its cold though...hmmmm
Sgt
Car: 1991 Fairlady Z (JDM) Twin Turbo
You are hearing the alternator.
One thing you should do with your deck and amp, is check your power and ground wires.
I am not too sure what you can do to eliminate this. A voltage stabilizer may help, as would a capacitor for your amp.
This is not going to cause any issues, it is just annoying.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Sgt wrote:You are hearing the alternator.
This.
Also, check behind your radio (if you have an aftermarket deck) to see if they installed a "Bose conversion" box thing. That's what was causing that issue for me. It was basically bypassing the ground for some unbeknown reason to me.
Ghut300zx
Car: 1995 300zx N/A
thats what i figured. thanks
jona300zx
Car: '95 300ZX N/A
Check your amplifiers....i had the hissing sound too and i adjusted my amp and checked all the wiring and it ceased. they also sell some sort of filter if im not mistaken. your local stereo shop should know about this.......
vape-one
Car: 1990 300zx
rjmancia wrote:hey i hear that static sound too! and i drown in gas fumes in the morning... it only does it in the morning when its cold though...hmmmm
If you smell gas in the morning it's because you need to check your fuel line connections one or two need tightened up.. The cold makes them come loose..
An as for the static sound rjmancia they make a noise reduction for radio's.. If you have a Walmart there just look in the stereo department...
Zwicked
Car: 1990 300 ZX tt, 1990 240SX
It could be your alternator on it's way out. If it's aftermarket stereo, make sure to run the RCA cables and power cables on opposite sides of the car so they are as far apart as possible.
