Starts then Dies
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
95GTSTR33
Car: 95 R33 GTST
Starts then Dies
Postby 95GTSTR33 » Mon Nov 14, 2016 4:14 pm
95 GTST Greddy style intake q45 TPS Cobra MAF header Garrett GT35R External OBX Wastegate set on spring pressure Apexi Power FC Denso 740 injectors. have a start then die condition vehicle will fire rev to 1500 RPM's approx then immediately die. throttle application makes no difference. fuel pressure is good. CAS is operating properly. timing is correct. any help is appreciated. thanks in advance!
T
centralcoaster33
Car: 240SX #5-1997
Re: Starts then Dies
Postby centralcoaster33 » Fri Nov 18, 2016 3:51 pm
Is this the result of your mods or has it been running and just started doing this? What codes does the ECU provide? I'd be suspect of MAF, TPS and O2 sensors, maybe vacuum leak, but I think we need more information like when was it working last and what's changed since then. Thanks.
Welcome to NICO Club!
95GTSTR33
Car: 95 R33 GTST
Postby 95GTSTR33 » Sun Jan 15, 2017 4:53 pm
Sorry for the delay. Not entirely sure I inherited it as such. I can verify the timing fuel pressure CAS functionality spark etc. it will occasionally hit rev to 1200 or so then immediately die.
dee242
Car: 1998 r33 gts-25t 40ae
Postby dee242 » Tue Feb 28, 2017 9:04 pm
how are your plugs ive had this happen to me during cold weather and i see that your running a power fc
ericherm1
Car: 1997 Pickup XE 2.4L 4x4 Single cab short box
1991 BNR32 Skyline GTR
1991 240sx SE SR20DET + S13 Silvia Front end swap (Sold)
Postby ericherm1 » Tue Mar 14, 2017 8:11 am
Are you running MAFs or MAP? If your running MAFS then you will have hella problems with open air BOV causing the exact issues your seeing. Sounds like you need to have the Power FC inspected too. Do you have the OEM ECU? These are the areas I would start in.
Remember: Suck---Bang----Blow
Air, Gas, spark that's all you need.
M35Squirrel
Car: 1990 GT-R, 2011 M37
Postby M35Squirrel » Wed Mar 15, 2017 12:33 pm
I know this is an old post, but I just came across this trouble shoot for Power FC. Perhaps beneficial to future Power FC user as well.
The PowerFC manual states to start the car, ensure no errors are present and let the car idle for at least 30 minutes. During this idle period wait about 10 minutes, turn on the air con, wait another 10, turn on the demister, wait another 10 minutes or so and then your car is ready to drive. If you short cut the self learn idle procedure once the car is turned off and back on again it will simply stall each time. If this occurs you must factory reset it again and do the procedure from the start
ericherm1
Postby ericherm1 » Wed Mar 15, 2017 12:49 pm
Yup, excellent point!
95GTSTR33
Car: 95 R33 GTST
Postby 95GTSTR33 » Sat May 20, 2017 3:42 pm
Still in the same boat. It's got a Ford cobra MAF. Same condition plugged or unplugged on the MAF but the power fc is registering the MAF. It is hitting just immediately dies. it will not settle into idle.
Return to “GTR Forum / Skyline Forum”
