doownehpets »
https://forums.nicoclub.com/doownehpets-u99438.html
Wed Dec 03, 2008 9:51 am
In the last week I've been having trouble starting my J30. Got in my car, started it up.. sat there for about 5 min and had to run inside to grab something came out and it wouldn't start back up. I know about the flooding problem with the j30's and attempted flooring it while cranking it for ten seconds.. it seemed like it was barely getting any fuel. I had recently changed the air filter, fuel filter, spark plugs (OEM). So then my neighbor and I deduced that it could possibly be the fuel pump. After replacing the fuel pump I was able to start it, but the rpm's drop and it died. So unless i give it gas the for the first 30 seconds or so while it's warming to keep the rpm's at about 1100-1200 it dies. Once i've held the gas peddle to keep it alive for a while i let go and it'll idle by itself. But then... unless i warm it up as soon as i put it in gear it dies. It also has a hell of a lot harder time trying to start if it's already died once, probably flooding, but even if i let it sit for a bit, still same problem. Wen't to pull codes, the only one i get is 55, everything's all good. Cleaned the MAF sensor, still same problem. From what i've read it could be the IACV being clogged up, but that thing is a pain to get to. Any suggestions?
