GRNQ45 »
https://forums.nicoclub.com/grnq45-u12244.html
Sun Dec 28, 2003 5:22 pm
Thanks Guys......I checked the MAF sensor connection and cleaned the recepticle pins. I then tried to restart and held down on the accelerator until it turned over and started. I still have a rough running vehicle. But it got me back to Ohio, now the real spending begins. Have yet to check for 34psi from the fuel pump because I think injectors number 4 and 5 are bad, mucho sporadic ticking. Nothing close to what it should be. Is it possible to have a bad fuel pump and injectors at the same time. My injectors are yellow. Where is a good place to get a couple to replace the defective ones? I am told my chain guides are not the same ones on the 90 - 92. I am still going to have them looked at again because the more I read the more I am getting a little freaked out about something as terminal as screwed up heads and the such. Once again much appreciated.
GRNQ45
