starting issues
skinZ32
Car: 1992 300zx 2+2
when i go to start the car it always starts but, i used to just turn the key ,crank and turn right over and start all in one motion. now it seems that i have to hold the key longer and it cranks a couple seconds longer then starts.(its not the same as before) when this happens the car seems sputter a little like its not getting enough fuel. once it starts and i rev it , the idle is good and where it should be. it seems like this issue is getting a little worse over time.
any input would be nice
skinZ32
Car: 1992 300zx 2+2
bump
i could really use some input on this it seeming to get worse. now i have to hold the key for multiple seconds and and soemtimes it doesnt turn over and start and i have to turn the key back and try again . it eventually turns over but not in the smooth way it used to(seems to sputter for a seconds once it starts). this is not the way it used to be an im affraid of getting stuck somewhere not being able to get it to start.
thank you
