starting issue 2011 Rogue SL AWD
dconrads
Car: 2011 Nissan Rogue SL AWD
The original problem was that it would start. After replacing the starter, I accidently crossed the charger cables. I replaced the Dorman 956-131 Battery Circuit Fuse connector and IPDM. It still turns slow and will not start. Any help would be appreciated. Thanks.
dconrads
"it would NOT start"
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Unless maybe you have a problem with your ground connections or a damaged battery, I don't think you'll get anywhere with that sort of issue without scanning the vehicle. If it's I-key then you can rule out any ECU's not communicating (if the ECM/TCM/BCM/IPDM weren't all online then it wouldn't crank at all), but if it's a steel key then all kinds of things can let it crank but not start. Do you have a red "key" lamp lit solid in the cluster when you turn on the ignition?
Return to “Rogue Forum”
