Starter/Solenoid problem
cromag2k6
I have recently been stranded in a parking lot because my 240 would not start. When I turn my key, absolutely nothing happens, no weird ehhhh sound and no clicking sound, absolutely nothing at all. My battery works fine, all my lights come on and I tested it with a voltage meter. To my suprise, the starter was getting the power needed, but still nothing happend at all. To the best of my knowledge I belive it is a bad solenoid and was wanting to just be sure of that before I go and replace it since I am a college kid with very little extra money to spend on these types of things. Any help and input is greatly appreciated.
-chris
S13DrIfTmEkAnIcS
Car: 89 240sx
solenoid, just go get another starter
inferno240
Car: 90 nissan 240sx (monica), 96 chevy cavelier (jazz)
wo wo wo sorry to steal this thread for a sec ... but i have the same exact problem changed the starter twice still happening can it be anything else ignition or module ..... battery is new starter is new cables are tight please help us
inferno240
bump
WWJD
there's a little blue box on the front pass. side of the car that went out on mine I think it's the ign. realy (not sure of the name) or you could do what I did 4 a while... LOL put the car in nutral and with a big screw driver touch the groud and power terminals on the starter 2gether and the car should strat right up. I did that 4 a few mouths
inferno240
you have automatic ? i have manual ....... cant i replace that box?
WWJD
5 speed. and yes you can change it, I did
tjmhillz
Car: 2001 Lexus IS300 Turbo
i had the same problem. car wouldnt start replaces teh relay(blue box between bat and fender) and it started right up.. part costed $22 at advance auto. also check to make sure theres no corrosion on the terminals and cables. and check your grounds.
inferno240
thanks guys .... the other day i was under my dashand i saw an old alarm that the last owner had there i complete took it out like 5 pounds of cable lol .... so after taking all that out i see my car starts alot better now (knock on wood ) ... bt i think im going to change that box anyway ...
nka24racr
Car: 91 acura integra, but missing my chuki......
I too have this problem but i get a single click. i guess it could be the starter solenoid, but i dont think its my ign.
WWJD
track down the click. fix it and bam your goood to go
Zilvia33
Car: 91 240sx Hatch SH
i too have this start problem.
so from what i read, replace the starter, after that try the blue relay box? Where is it location?
WWJD
dont replace anything that isn't broken'. take your starter somewhere to get tested. If no good, get a new one. the blue box is where you Bat. is. right in the corner behind the head light you could test that out as well
cmoody2006
Car: 1993 Nissan 240sx vert
ok like the rest i'm having this same prob. well would the car overheating and the radiator bursting cause any of this? I fixed the radiator temporarily and put a new thermostat in it. Then ran the car for a couple days. I have a remote start on my car and it wouldn't start with the remote so i tried the key and still wouldn't start so i unhooked all the remote start stuff and still nothing. I'm in college right now and car is at home i'm going to take the starter off and have it checked when i get back. Weird thing happened tho. I was able to push start it once - pop the clutch- and it ran fine then i went to do it again and it wouldn't so i checked under the hood. The positive lead on the battery was really hot like there was a short in the system. Plus all my lights were dimming afterwards and it drained all the juice from the battery. So i just left it be and had my parents take me back to college
WWJD
hot wire....? check your ground wire or up grade it 2 0gauge wire.Also alot of aftermarket alarm systems may cause your car not to start as well, built in kill swich
cmoody2006
I've got an hks engine ground wire kit. I've got plenty of good ground wires. Anyone ever heard of the crimestopper car alarm? My model is the cs-2016 if you're wondering
lamchops
Hi I just got my 97 240sx its an automatic and i just replaced the alternator battery since it was testing bad then my car wouldnt start so i tapped the starter and it started. The next day my car wouldnt start again and it would click or crank when i turn the key so i replaced the starter now all i hear is a clicking sound after putting in the new starter. I was told to replaced the inhibitor relay and also the starter relay but I cant find the location of those 2 relays....please help
