Starter engagement issues
Momosc
Car: In market for Z32
'91 Z32 N/A 5-speed. 145,000 miles. Got this car 1 1/2 years ago and love it. Engine is bone stock. Here's the issue: 9 times out of 10 it starts just fine. Then every once in a while, rather than starting, it'll make a high pitched, high rpm sound which I'm assuming is the pinion gear not extending fully and engaging the ring gear as it should. Might be catching just a corner of the ring gear (not a pleasant sound :)
Give it a minute, maybe run the shifter through the gears, or even just open and close the door (?!) and it'll start fine for another week until it acts up again.
It's not a hardware issue, because this is the 3rd starter and second flywheel, and the symptom remains the same.
Voltage? I think I'll replace the hot wire from the battery to the starter next. I notice that previous owners have allowed a fair amount of oil to drip on it through the years.
What do you guys think? What else would you check?
Thanks, Mo
themadscientist
I think you have a good thing to try next with the wire. You have definitely ruled the starter and flywheel out.
