Hi, Sorry for a delay.
This is what I’ve done/discovered so far.
Cleaned Air box and air flow meter and connector, reset ecu and the problem is still there. No change at all. Then yesterday I’ve discovered that a plastic pipe (air duct) that goes from the air box on the passenger side is disconnected from the next pipe that I think goes to turbo. It will take some elbow grease to reconnect the pipes together due to a lack of space. Can that cause a problem? I believe the pipes were disconnected for a long time and did not cause any problems or maybe I’ve not noticed it.
That is a picture of the air duct that is disconnected
