ca18detdrift wrote:OK so now the engine is sitting in the engine bay, and everything is about 80% done. Just have a few electrical problems.
1: the fuel pump isnt coming on, and i checked the black w/ pink stripe wire (fuel pump relay) and it seems wired right.
2: Is there a plug that goes into the oil pressure sender (near the oil filter)?? I dont seem to find any plug that goes in there, is there one on the main engine harness or the lower harness?
3: For the O2 Sensor, do you just need to hardwire it to the ecu pins 29, and 115? I can't find the plug for this either.
Well thanks alot guys, hope i can get this problems solved, so i can have my car up and running
1.Print of the pages of the FSM regarding the fuel pump. Start from the pump and work backwards (that's how I always troubleshoot anyway) checking for voltage. You can bypass the relay by pulling it out and then using a jumper to short the wires together. Don't short the wrong ones or you'll burn up the ECU.
2.Yes. It's on the lower harness. Single wire. White IIRC.
3.I don't have the FSM on this comp, but if you don't have a plug/wires for it, then you can just hardwire it to the ECU.
