SRI on a CVT Sentra
DarkAquarius
Car: 2010 NISSAN Sentra 2.0SR
Has anyone installed a SRI (Short Ram Intake) on a CVT 07+ Sentra? I interested about the pros / cons of installing it with this transmition. Any input is appreciative.
djtorello
Car: 2008 nissan Sentra SE-r
I love mine. I bit more power, but a bit more noise as well, which it to be expected.
i will warn you though, the old airbox is a horrible PITA to remove on both the 2.0L and 2.5L
DarkAquarius
You have the cvt on your se-r? I just bought the WeaponR SRI for the 2.0L Does this help Fuel Economy?
Modified by DarkAquarius at 1:13 PM 7/2/2008
nametakennow
Car: '06 MINI Cooper S
The reduction in restriction in the intake system (i.e. increase in intake efficiency) will give you a bit more power and fuel economy regardless of transmission.
Engine power is irrespective of the transmission. The CVT is tuned to hit the most powerful/efficient ratio depending on throttle position. An intake, for instance, increases power throughout the rev range, so whatever power increase you get at whatever rpm the CVT "sticks on" will be there regardless. The CVT can't cut the amount of power the engine is giving it at a given rpm.
DarkAquarius
Thanks for the input. Do you know if where I can find the instruction on how to remove the OEM air filter?
djtorello
DarkAquarius wrote:Thanks for the input. Do you know if where I can find the instruction on how to remove the OEM air filter?
Here you go, BTW you are gonna have to remove the battery in its entirerty to get the bolts at the bottom, so you will have enough room to pull the airbox out.
nametakennow
Your SRI should come with instructions, but the info posted above will definitely do the trick.
DarkAquarius
Thanks, I'll take it apart and put it back together just to have a feel for it. Thanks for your feed back... Those instruction looks like you got the from a manual. right. Where can I get this information?
DarkAquarius
DarkAquarius wrote:Thanks, I'll take it apart and put it back together just to have a feel for it. Thanks for your feed back... Those instruction looks like you got the from a manual. right. Where can I get this information?
Never mind. Found it... NameTakeNow sign.
Thanks again.
gotak
Car: 2007 Sentra SE-R
You guys posted the 2.5 engine's air intake stuff. The 2.0 is different.
DarkAquarius
The pics are probably from a 2.5 cvt but the diagrams are from the 2.0It is indicated in the top right corner of one of the pics the MR20DE.The information is correct.
nok610
Car: 2007 Nissan Sentra 2.0S CVT
Hey Dark,
Did you get the SRI installed yet? If you did, how does it sound? I'm just curious because I thought the CVT would sound a little annoying because there is no pause (gear changing) while driving.
I want the Weapon-R but not too confident on how it will sound. Thx.
djtorello
gotak wrote:You guys posted the 2.5 engine's air intake stuff. The 2.0 is different.
Nope, the pics are from the 2.0L . Im the Tech for the Car club im in, We have (2) MR20DE, and then my Lonely QR25DE. So i have pics for both.
You can also tell the above pics are the 2.0L simply because the air filter is different then the 2.5, also the snorkle end is a compleletly different design. The MR20DE uses part of the battery tray as the intake piping, the QR25DE does not.
DarkAquarius
gotak,
I installed the Weapon-R SRI about a week ago. It sounds great. With smooth acceleration you hardly know the difference, but rev the engine up and after 2000 RPMs you'll hear the it. If you have an exhaust, or Catback system, you notice the symphony between intake/exhaust.
All in all, with just the intake, I gained about 10hp, but my MPG(25/34) reduced to (22/31).
So... just the results I found so far.
nametakennow
DarkAquarius wrote:All in all, with just the intake, I gained about 10hp, but my MPG(25/34) reduced to (22/31).
Probably lost MPG cause you're enjoying the noise . Could also have been variances in traffic levels. The want to make noise goes down a little bit with time.
nok610
DarkAquarius wrote:If you have an exhaust, or Catback system, you notice the symphony between intake/exhaust.
I'm so tempted to get the Weapon R and an exhaust but it's my everyday car, I don't want it to annoy me and others all the time.
gotak
Was 10 hp dynoed? Or butt dyno?
nok610
Dark,
Got any video or audio clips? I got a CVT 2.0 and I'm dying to hear what it sounds like before I start saving up some cash for an intake and exhaust.
DarkAquarius
Its an estimate, It might be off by a couple hp's.
DarkAquarius
Unfortunately, I do not known a video cam. I know someone that does. I'll see what I can do to post it as soon as I get the clip.
nok610
Nice, I'm looking forward to it!
nok610
Just installed the Weapon R SRI this past weekend. A few things I wanted to note, especially to 2.0 CVT owners. You won't hear it kick in until you accelerate and stick at 2000 RPM's and even still it's very mellow. Go a little higher and you still won't hear much more until you kick it past 3000 RPM's. Step on it hard and you will hear it growl. It's a very low tone which is very much appreciated and aggressive sounding. Overall, when driving at normal speeds, you will hear it minimally.
I'd also like to point out that I am still running a stock exhaust which I'm planning to replace sometime in the future. I'll post a before/after video after the exhaust swap to give 2.0 CVT owners, who haven't taken the plunge yet, an idea of what to expect.
Modified by nok610 at 8:44 AM 9/10/2008
