sr20det cam sensor
jchowell396
Car: 93 240sx sr20det
just had my sr20 rebuilt but when i got back from the shop it was falling on its face i looked and the bolt was missing from the cam sensor i put one it and it fixed but its still not exactly right and i know thats the reason how far should the sensor be turned???
IBustV8s
Car: 1992 240sx
take the cam sensor out and on the end their are 2 dots and line them up one in front of the other and put it back in. you may also need to set cylinder 1 at tdc. the second notch to the right (which means there is only 1 dot to the left) on the harmonic balancer, line it up with the little prong that sticks out over top of the hb. that should put it back in time.
jchowell396
thanks man that helps alot
