alright heres the deal....just installed tomei 740's with a nismo FPR, a Z32 MAF, and an RS-Enthalpy tuned ecu (ecu had dyno time with martin from enthalpy)....the ecu had the same injectors , fpr, and maf (exactly bought them off that car...it ran).... except instead of 264/264 cam's i have Crower 272/272's with hks gears and supertech springs/retainers and degreed in properly, other car also had 9.0 : 1 or so compression and a .83 bore....im stock bottom end. also it had a gt2860r with t3 exhaust side or some hybrid like that running 1bar. and i have stock turbo on 13psi....now my car breaks up BAD in higher rpms and either at 50% throttle or 100% or lower rpms at barely any throttle lol may be too rich i guess but i was told it shouldn't be THAT much too rich and i would think it would only be under boost, or my Z maf.....if its my MAF i really cannot figure out the issue and am getting unhappy lol
maf was wired correctly no doubt triple checked and i had some resistance throughout the chassis so i ran the wire for chassis ground all the way to the negative terminal on the batt. lol ...its a tomei z maf plug ...so its color to color cept theres a brown for chassis ground. black with white is 12v (which i have on the plug) black is ground (continuity to chassis) , brown ground, and white to white which is signal wire....with ignition on car not running i was told i should have around .4volts DC on white.....had NONE to either ground wire or chassis.....but from black with white to the wire it would lower the voltage to around 9 or 10volts ....
