evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Mar 04, 2011 2:53 pm
I do not recomend a pallet motor especially one taht isn't fomr the US, when you buy a pallet motor you are buying a miles unknonw engine, they might telly ou it has aobut 30k but the truth si that unless ti includes a cluster, ti is milage unknown and most likley is they decided to sell ti as a pallet and nto a clip it's got a lot more than 30k miles on it, I've had nothign buy bad luch with pallet motors, and I assure you ever "low miles JMD engine" I have bought (3 of them) have had more miles and smown mroe ware that the "high miles" engine I was replacing, if you watn to buy a used enigne get one from a reputable auto recycler, a good reputable recycler will document the miles and running condition before they pull the engine and offer a period warranty and you won't have to wait on a container to find out what you get
also I never suggest someone swap in a smaller engine, it just doesn't make any sence to give up displacement, more displacement = more potential power at lower rpm
people who say it's cheaper to replace than to rebuild have generally never priced a rebuild, and as witht he swap the more work you do the less it costs, if you pll and disassemble your engine and it doesn't require overboring or oversized pistons you should be able to rebuild the block and both heads for under $1000, if you are paying someone else to do the removal and reinstal taht figure could easily double
as for fuel economy, you should be able to get high teens in city driving, and high 20's on the interstate cruising at 55, mixed driving can get you anywhere in between, as for economy of having a smalelr engine pushign a heavier car than it ever came in who knows, probably better than the vg but worse than a 240sx
now if it's power you are after, you can look into a vg30et swap/conversion, you can look for a wrecked donor or just collect the bits you need to convert your's or a salvage vg30e to turbo, follow the link in my sig to my turbo converted z31
