sr20
sikkV
Car: 2002 SE-R SpecV
has anybody done an sr20 swap with their specV before??? if yah,can you give me a list of things i need and guidelines..thank you...
nametakennow
Car: '06 MINI Cooper S
Pretty much uses 00-01 Sentra SE parts (front/rear motor mount crossmember, harness, etc) plus the engine, plus some sort of management system (B15 SR ECU hasn't been cracked) and go from there.
Honestly though, you're probably better off with a VQ swap or a turbo'd or built QR.
sikkV
wow..well if the sr20 would cause us too much work...i might as well get the vq...less work..and a v6...
sikkV
any vq motor will work???as long as its 6 speed??coz i saw a post in the forum: that the b15 transmission will match with the vq?? am i right??meaning easier swap for my specV?
nametakennow
There's a thread in the Table of Contents that has some information you'll want if you're interested in the VQ.
It's the VQ35DE out of an Altima or Maxima that is used. There's a bracket required to make the SE-R trans fit. The other details are in the aforementioned thread in the ToC or can be had by talking to the swap guru (whose contact email or something is in that thread).
