SR Hot pipe on CA with SSAutoCrap mani
float_6969
The hot pipe is way too long. I don't know if it's just because it's the SR hotpipe, but I think it's because of the manifold. I'm having it shortened today. We'll see how it goes. I also accidentally ordered an S13 FMIC kit so the cold pipe is way off. Grrr. I've had less trouble rebuilding the motor than I had since I re-installed it. I did jury rig it with just the cold pipe and the MAFS stuck on the end and got it started, but it's running like crap. I think it's electrical, but I don't know for sure yet. Has anybody tried to start their CA w/o the O2 sensor hooked up? I didn't how picky the ECU was about getting a signal from it...
WeldingHank
Car: 1989 240sx CA18DET
strange, why would it be in a different position? that would mean the exhaust wouldn't fit either.
jjwilks240
Car: cars
ssac sr turbo extension didnt fit with sr downpipe for me.
i started my car with no o2 it was just really loud and you cant give it throttle
WeldingHank
this is all starting to scare me a bit! i have an SSAuto manifold, Megan dump tube and S14 T28. now i am just hoping it fits.
kuruma
WeldingHank wrote:this is all starting to scare me a bit! i have an SSAuto manifold, Megan dump tube and S14 T28. now i am just hoping it fits.
I have the same deal, nothing installed yet. Let me know how it goes. I am curious
NeedCAforS13
Car: CA swapped S13 coupe
no its not the manifold, its the HOT PIPE! I have posted this numerous times that an SR pipe is too long... I tried both an Enjuku one and a Cusco one, both were about 2 inches too long (on the stock manifold). Ryan doesn't seem to pay attention very well
and the car should start and run fine with the o2 sensor unplugged... mine does at least. It doesn't run great like that, but it does run and drive.
Sean
WeldingHank
my greddy hot pipe fits fine. it just sits a little crooked.
rico05
Car: 1992 RMS13 w/ CA18DET
On the topic, when are you making those hotpipes Sean? I'm waiting
float_6969
NeedCAforS13 wrote:no its not the manifold, its the HOT PIPE! I have posted this numerous times that an SR pipe is too long... I tried both an Enjuku one and a Cusco one, both were about 2 inches too long (on the stock manifold). Ryan doesn't seem to pay attention very well
Sean
Sorry Sean, I'm a bad, bad little monkey. Will you spank me? I mean.... Uh... I was just kidding, seriously.
I'm working again on it tomorrow night. I have to get a test pipe on it before I start it again though. The neighbors came over and complained last time. Oops
float_6969
Everything else fits perfectly. I wouldn't worry about it. I didn't really think it was the mani's fault. All of my coolant and oil lines fit perfectly, no clearance problems with my 3" fly'n dumpipe. My apex N1 Single doesn't line up right, but I don't think it has to do with the dumpipe I'm using. I'm just cutting and rewelding the test pipe.
NeedCAforS13
float_6969 wrote:Sorry Sean, I'm a bad, bad little monkey. Will you spank me? I mean.... Uh... I was just kidding, seriously.
<3... but no. Glad to hear everything else is going relatively smoothly though can't wait to get this CA in action!
Sean
float_6969
Yea, I drove it for the first time tonight. Somehow I didn't get my timing belt right and I was running about 10*ATDC. I'm suprised that it started or ran. But I got that fixed and it seems alright now. I think I've got a stuck lifter so I may have to get a new set, but thats not major work. I threw some vac lines on it tonight and hooked up my SOHC intake and started it and drove it. That CA isn't too bad of a motor in NA form really. It's a little gutless down low, but the butterflys are just running open so that's got something do with it. It revs real nice with the lightweight flywheel too. I'm ready for the turbo though....
