Beems240sx »
https://forums.nicoclub.com/beems240sx-u97311.html
Mon Mar 15, 2010 4:29 pm
S13 SR20, S14 "WC" ECU, front mount, hks bov, isis intake manifold, 3in exhaust, 14psi, 18 in vacuum
i noticed this about a week ago, it started to bog when i gave it gas. at idle my AFR gauge will be at 14.7-15.1 like normal. then ill blip the throttle and it will bog and read about 17, which is WAY lean. after that initial bog it will rev to 7K without a hiccup with perfect AFR throughout. this will happen at any rpm, say 2nd gear crusing at 4K rpms, punch it and it will go lean for a second then back to normal. it is more intense when the motor is semi-cold and gets hard to actually drive it. it is NEVER lean underboost and pulls hard.
im leaning towards the MAF, i will be testing the maf for correct voltage to the ECU. another thought is the ignition timing as i couldnt seem to get it to work with my timing light correctly so its just "close enough" and lastly is the FPR or fuel pump. but since all other afr's are correct im not so sure on those.
