biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Tue Nov 01, 2005 9:36 pm
it bolts up != it bolts up with a conversion harness :P
yes you said you are using a harness earlier in the thread, but when you just said "it bolts up" that means something different.
it's fine if you've got the SR ECU and a conversion harness, but if you have nothing, it makes more sense to try and get the S14 (if it really bolts up), since getting a conversion harness + S13 SR ECU is likely a bit more difficult than getting a S14 SR ECU..
I'm gonna have to find someone local one of these days w/ a S14 SR and see if I can plug in my chopped up 2nd harness into his ECU
