sr clutch slipping under boost serious ?
jonathon
Car: 1991 240 sr20det
1996 ford ranger
first thanks in advance for all the help
second i have searched the forum in here and the sr one but still no fix (i hope its not the clutch) :/
this is the problem just dropped my sr in and went for a test drive....noticed the clutch engaged at the top of the pedal still just wanted to see what happened before i messed with it...turned on the street engaged fine untill boost then major slipping...as in slips as soon as there is any load
got to the house searched on here....adjusted my pedal rod counter clock wise which brought the engagment point closer to the floor but the pedal only moves a few inches now....rebleed the system at the slave cylinder and tried again. same problem just it engages closer to the floor....
my question is what am i doing wrong? is there something else i should check? i dont want to pull the trans. without trying everything else first.
again thanks
UPDATE!!!
another thing it might be is i used a 91 ka slave cylinder that had a push rod...it had to fight it to get it on....is this the wrong slave cylinvder?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Brand new clutch? Did you follow the break in procedure? Rear main seal good?
jonathon
1996 ford ranger
its the clutch that came with the motor and i just got it in....finished doing all the research and the only difference between the slaves cylinders is the older style has 1/16 smaller cup size but the push rods are exactly the same so its not that....im going to take the slave cylinder off and start the car in 1st gear just to make sure its the clutch...but im sure the system is bleed out correctly...guess i should of listened when someone told me to check the clutch before putting it in :/
92SEric240SX
Car: 1992 Sileighty with S13 Blacktop SR20det
Don't sweat it man, I had to do the same thing on my car when my clutch let go on me, put the car on cinder jack stands. Just be sure to have a friend or two to help you wiggle the transmission off.
jonathon
1996 ford ranger
92SEric240SX wrote:Don't sweat it man, I had to do the same thing on my car when my clutch let go on me, put the car on cinder jack stands. Just be sure to have a friend or two to help you wiggle the transmission off.
If you dont mind me asking...how much did you pay for your clutch and where did you get it from? i was looking on ebay
http://cgi.ebay.com/ebaymotors/F1-RACIN ... ccessories
or maybe this one...im just looking for an OE one i dont need a stage 2 or anything
http://cgi.ebay.com/ebaymotors/GRIPFORC ... ccessories
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
I like more know clutches.
Spec, Exedy, ACT
jonathon
1996 ford ranger
agreed...im going to keep looking for one...but im going to try and keep i under 150.....im just going to get my flywheel resurfaced.....if anyone knows of somewhere to one around that price it would be great.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Any machine shop can resurace it, but you need to know what te thickness is afterward so you can shim if needed. You also want new flyweel bolts, and a new pilot bushing
What about OEM clutch? Chances are if you go with cheap, it wont will fall apart sooner than later.
jonathon
1996 ford ranger
after doing some more research I found that it is claimed that the 89 nissan maxima clutch is the same as the sr20 one....does this hold any truth? becuase i can get a good oem clutch kit local for 130 then turn the flywheel for about 40-45
jonathon
1996 ford ranger
found this old post...anyone have any experience with them?
maxima-clutch-for-sr20det-t350878.html
92SEric240SX
My friend got in touch with Tennessee clutch supply a while back and they do have good stuff. They quoted me around $200 for a 2jzgte stage 2 clutch. Definitely try to get one from them.
92SEric240SX
My clutch btw, I got a exedy stage 1 from ebay for around $250
jonathon
1996 ford ranger
i got it fixed...had to cut the slave cylinder push rod...im guessing the fork is bent because i had to fight it to get it on....cut 1/8in off it :/ but hey its all good now....next thing to adress is the BOV i know some people are running some that are not recir. just need to find out which one...forum search here i come...
jonathon
1996 ford ranger
well its slipping again :/ just went ahead and ordered a clutch kit and going to get a new fork and piviot ball to...sweet deal
