you are right...... it wasn't the belt it has to be the beering that the first belt drives. either the water pump or power steering. the noise was gone and I thought i fixed it, but it just came back this morning. i changed the belt already so it cant be the belt.tyrodtom wrote:Bad waterpump bearing, or alternator bearing, idle pulley bearing, if you have a idler pulley.
