squeaky sounds over 2500 RPM
Nismo180
I was just wondering if anyone could point me toward a solution for a slight squeak sound that comes from the engine when I rev over 2500 RPM. My guess is timing belt but has anyone else encountered this problem? Thanks in advance for any assistance.
s0ldats
if you have a 240, it's not your timing belt since you have a timing chain. i would check the fanbelts to see if they have oil on them, are tensioned properly, or are wearing out.
Nismo180
thanks much, i'll look at the fan belts and see if that's it
Tex
I had a similar problem. Does it sound like your engine fan is running at an extremely high RPM as well? Mine would do that and start a high frequency sqeak at around 2500 RPM. Problem was a burnt out fan clutch. Cheap fix, $120 or so.
Hope you find out what it is.
1991240xs
anyone wanna tell me real quick how to replace the fan clutch? I need to do this this weekend~
i2ice4m3
Car: COUNTERSTRIKE!
ouch...120 bucks! you might as well do a electric fan conversion : P
deCksy
yeah i'm having the same problem, i'm go check my fan also
