Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Dec 13, 2003 4:15 am
Determine which rod is knocking by using Consult to shut individual cylinders down. The change in sound and doubling the sound.
Never seen one knock at 120k but always a first time......measure the hot idle oil pressure and report [>14 psi?].
Come down to Atlanta and we will introduce you to the local Japanese engine warehouses..........where you can see what you are buying [for $1500].........you might pay Byron $100 to help you select the best looking one and take it home.
We could pull the valve covers and examine and change the plastic valve guides out and R&R the engine for your install.......the actual swap takes 25 hours [$1750] once R&R is complete on the newer engine
Be very careful about who does the engine work, as many don't do the days of R&R on the newer engine..........when you spend $1500-$2,000 on a Quality takeout that is only the begining of the extra $3,000 in work.............a quality total job should run around $5500.
Hard to find low mileage well maintained engines on Ebay at a reasonable price delivered.
