sr20goofus »
https://forums.nicoclub.com/sr20goofus-u32686.html
Mon May 24, 2010 2:03 pm
Heavier in the front being a RWD car, you want the rear to be able to move a little more to compensate for torque and squat, it helps with traction.
Most coil over kits come with a 8k/6k setup with springs, which i believe is around 450lb/350lb front rear setup. As the car gains power and downforce the spring rates should also increase at the same rate. For roadracing i want a 12k/10k setup which is 670/550lbs, but my car also has around 300whp and I have a good bit of experience with it. Dont aim strait for ideal setup, go with something softer and then change the springs out after a few events so you can feel the difference and learn the car better.
