Spring installation
drifter
Car: Drifting, cars, etc.
I was wondering if anyone in the SoCal area is willing to install my springs for me (when I get them) for under $40 bucks...I have absolutely NO experience with suspension and it would be cool if someone taught me some stuff. Thanks in advance!
ESPER
hehe, same here, iwould do it myself, but i am not sure about using a pring compressor.......
-Rookie
ESPER
hehe, same here, iwould do it myself, but i am not sure about using a spring compressor.......
-Rookie
Structure240sx
i did mine without a spring compressor might have been a lil bit of a risk but who really needs a head. i would def help u out if i wasnt on the other side of the country
hopesfallhxc
yea its not to safe but you can always just get a bucket and line it up and when you loosen the nut on the top of the strut it'll just shoot out into the bucket, most likely breaking the bucket. so dont use a really nice one, and you probably shouldn't do it that way. the best option is to take your whole strut asembly out and take it to a local shop. they usually have a machine that'll do it in 30 sec. then jsut slip the mechanic 5 or 10$ and you'll be on your way. good luck
driftaholic
Car: '91 Nissan RM S13
at my local kragen they rent spring compressors for like $5 a day.
sultan
i think one of the mods of the infiniti mechanic forum does some mechanic work for people, screen name is DAEDALUS and he's in El Segundo. email him and ask if he'll help you. he's got a hydraulic spring compressor, and just about everything else you can think of.
Cyberkreig
Car: 1993 Nissan 240SX SR
A friend of mine used to use the "2 jack" method. Jack the car up and put it on stands..(hydrolic jack) then he would use the jack to put the shock assembly under light load, then loosen the top bolt. It always seemed like a good way to get injured to me.. I'll be taking my car to a shop.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
spring compressors scare me, you could poke your eye out! along with the rest of your head.....
drifter
bump
My friend was gonna do it for me for $20, but he got called to duty to Iraq....bummer....
240Degrees
careful when you take off the nut on the rear shocks. We didn't use a spring compressor, but we let it shoot out and the shock "exploded" err burst open to be more correct. Soo be especially careful if u r using stock shocks and use the spring compressor. good thing for me, i had the full coilover, so only stock part i needed to use was the upper mount (no pillowball mounts).
