Route it back into the intake stream.slideways wrote:unrecirculated BOV
OMFG!!1! 0ur ECU's are t3h ub3r l33tzorz!!!!!!!!!!11111!!!fraz wrote:its because your bov is vented to atmosphere.When you take your foot off and the bov vents, a lot of air gets let out of the intake.This air has been measured by the afm,so the computer goes OMG! OMG!, lots of air, fark, i better pump in a sh1t load of fuel or else it will leanout.
When decelerating, this fuel is not often burnt, so it goes into the red hot exhaust manifold where it burns and makes the big flame you see.
its not so much the ECU as it is just the factory air metering setup. most factory cars do similar things when vented to the atmosphere.DjLiquid wrote:
The problem that I have with the blow through setup is that you basically HAVE to run a catch can. If you don't, you'll get oil all over the MAFS and screw it up. It's not that big of a deal, but to hook one up correctly on a boosted car can be a bit of a pain. It's not nearly as straightforward as it is on a NA car. PLUS, I don't know how he feels about chopping up his cold pipe, PLUS, I don't know where his BOV is located. Outside of that, yea, I should have mentioned that!Pumaking wrote:come on float you could atleast mention the blow through system where the MAF is mounted after the blow off valve usually on the cold pipe about 12" before the Throttle Body.
