Spinning noise when trying to start
300z32
Car: 1990 Nissan 300zx
Hello 300zx owners. I have this problem in my 1990 300zx n/a. Sometimes ( not all the time) when I try to start the car it makes this spinning noise, kinda like a power drill. When it first happened I looked around under the hood and couldn't really see anything. I put the parking brake down rolled it back and tried to start it again and it started. Anyone know why it made the spinning noise?
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Sticky pinion gear or faulty solenoid on the starter motor, replacing starter is the easy.
Dvnrdrgz
Car: 300zx
itsa300zx wrote:Sticky pinion gear or faulty solenoid on the starter motor, replacing starter is the easy.
I just replace the starter in my car today. And it is making a wierd / rubbing noise. anyone have any idea what that could be? Does the starter need to be shimmed? No shims came in the box. Could the starter be Misaligned?
Dvnrdrgz
Car: 300zx
Does the starter need to be shimmed????
DCaff300ZX
Car: .
1993 CRP TT- Modified
If the starter drive gear does not mesh correctly with the flywheel, then yes it needs shimming. However, this SHOULD only need be done if there is a TT flywheel and pressure plate in there instead of stock NA (as I did when doing my 5 speed swap), as this should be the only time there is a mismatch...hence no shims in your starter kit.
Dvnrdrgz
Car: 300zx
DCaff300ZX wrote:If the starter drive gear does not mesh correctly with the flywheel, then yes it needs shimming. However, this SHOULD only need be done if there is a TT flywheel and pressure plate in there instead of stock NA (as I did when doing my 5 speed swap), as this should be the only time there is a mismatch...hence no shims in your starter kit.
Is there a way for me to tell if this swap has been done? I just bought the car a month ago and don't really know the history of the car.
aretwodetwo
Car: 1992 300zx twin turbo
could it be missing teeth on the flywheel? after lots of jamming thousands of times the teeth on the flywheel have a tendency to chip/break/wear down which would explain why you can go a few feet (which rotates the flywheel a little if you're in gear to a different spot with better teeth) then the starter gear grabs the flywheel and your Z starts up. its possible to take off the starter motor and with the car in neutral take a screw driver and push the flywheel to see the condition of the teeth. that's just my approach :) :bigthumb:
Dvnrdrgz
Car: 300zx
aretwodetwo wrote:could it be missing teeth on the flywheel? after lots of jamming thousands of times the teeth on the flywheel have a tendency to chip/break/wear down which would explain why you can go a few feet (which rotates the flywheel a little if you're in gear to a different spot with better teeth) then the starter gear grabs the flywheel and your Z starts up. its possible to take off the starter motor and with the car in neutral take a screw driver and push the flywheel to see the condition of the teeth. that's just my approach :) :bigthumb:
Starter solenoid wasn't engaging. That's why change the starter. Flywheel teeth are fine checked them before I put on the starter.
nissanfreak12
Car: 92 300zx 2+2 TT
You sure the starter you installed is good?
DCaff300ZX
Car: .
The only real test would be if the car starts without the clutch pedal depressed (no safety lockout), if so then it probably was an AT car swapped to 5 speed. The AT harness does not include the wiring for the safety lockout so that usually is not done during a swap.
