Hi, I have a 1996 240sx SE, and the speedometer either works or it does not. If I push and pull on the Trip Meter I can usually get it working. So this means something is probably loose correct? The previous owner got the speed sensor replaced, So would this be a cluster problem? I don't know much abut cars, so is this something I should take to a shop or can some DIY direct me?
Last week i posted a similar question but had some info wrong, the speed sensor is what was replaced.
Thank you, Thomas Moore
