speed limiter
1SlowCA18DET
can i cut the speed signal wire and remove the speed limiter as how the ka's do?
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
1SlowCA18DET wrote:can i cut the speed signal wire and remove the speed limiter as how the ka's do?
Apexi RSM or Pivot Speed thingy.
pulsar gtr
Car: NISSAN VEHICLES
If you know some that has an eprom burner and rom editor, it will take 2 seconds to remove or increase your speed/rev limiter.
Good luck,PULSAR GTRRafi
NeedCAforS13
Car: CA swapped S13 coupe
don't cut anything, just don't hook up the 5th gear sensor. There's no 4th gear sensor on the CA transmission, so the only thing holding you back is the 5th gear one...
Sean
1SlowCA18DET
ok thanks alot
Jezz_s13
Car: Sil80 Track Car
What speed limiter?
Perhaps JDM one have, but UK ones don't.
Sir. Driftalot
fsm dosnt say anythign about 5th gear sensor?
do you mean neutral switch? or?
NeedCAforS13
not the neutral switch, not the speed sensor, the other one (there is 3 IIRC). On the KA there is another sensor (4th gear sensor) so there is 4 total. CA only has a 5th gear sensor.
Sean
