spec clutch kit
1SlowCA18DET
the pilot bushing that the spec kit came with doesn't fit what do i do?
originalsin
a ka one should
float_6969
Try one from a pulsar. Check the sticky
1SlowCA18DET
got one for ka wouldn't fit, ca fit on transmission and then went into hole then became compressed and now i can't get trany on? what do i do now?
NeedCAforS13
Car: CA swapped S13 coupe
I used a pulsar one... those bushings break pretty easily, I jammed a KA one in there too, and had to split it with a chisel to get it out. Drill a small hole in it and whack it with a chisel and hammer and it should split nicely
Sean
1SlowCA18DET
so which bushing did you use?
float_6969
PULSAR PULSAR PULSAR PULSAR PULSAR!!!!!!!
NeedCAforS13
yeah, sorry that was worded badly... I tried to use the KA one and it got stuck like yours, so I eventually used a pulsar one.
Sean
1SlowCA18DET
c that the problem the one that is in there is the pulsar, it went in with no problem but now the alignment tool won't go into hole, another question do i push th e bushing all the way back or just to the edge?
