speaking of fuel rails
tyrannix
Car: go big or go home
just to clarify:even with 700cc injectors (at close to max) at under ~= 800 hp, the stock fuel rail should still be fine
would that be a true statement?
themadscientist
you are not feeding 800hp with 4 700cc injectors.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
700cc ~ 450-475whp MAX.
Jezz_s13
Car: Sil80 Track Car
The stock rail is being used on Bigtones car here in the UK at 600+ bhp, but as the other said you ain't going to get anywhere near 800 with 700cc injectors, you might be able to force it with 1l injectors.
here's my fuel rail with some work done to it, mainly the bosses for -6 fittings have been fitted to either end.
float_6969
Thats purty!
tyrannix
im not trying to get to 800... but i definatly want to be capable of flowing more than a standard mix would get 475hp at (because i will need to run more rich for the alcohol project) ... so.. 1000cc+ injectors it is
