Speakers in the back of cab
cleidus88
Is the wiring their for the back?
Q451990
There is a connector under the seat for them... I think it's blue and has 4 pins...
Heath
cleidus88
Went junk yard today pulled the rear speaker wires from x cab I cut the wires just behind the blue plug got home removed my seat no blue plug (mine is a reg. cab) how do I wire my rear speakers? I also got the ring to mount the speakers also but I had to cut off where the top screw hole is in order to mount them to the back of the cab. Can someone help me please.
Modified by cleidus88 at 6:25 PM 6/19/2009
RT
Car: 1991 nissan king cab pick up
You will have to run wires for speakers from back of radio all the way to speakers. Not to hard remove radio locate the rear speaker leads and wire them up. Run the wires down the side of truck by the door, remove the kick plates at base of door and run under them and just tuck wires under the carpet along the edge.
