Speakers Help something crazy goin on !
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
deaftosociety
Car: 08 nissan versa s 6 speed stillen strut bar
alright ive checked everything i just bought four infinity reference series speakers put em in my car back two speakers everything was working great after i put the one in my front passenger door and tested it to see if it worked all my speakers stopped working pulled it out couldnt figure out what the problem was started checking my fuses the one on my head unit and the one on my fuse panel is fine for some reason theirs no power going to those speaker wires ive checked both of em i donno whats going on so now i have no sound out of any of my speakers even my front left one which i hadnt changed yet, any help you guys can think of anything im not lookin at i know the connections should still be in place real well with the speakers because i havent even moved the car since, when i was working on it last night any help would be very appreciated as i cant live without music and right now this is killing me that it isnt working.
deaftosociety
talked to the people at crutchfield they told me to check the wires at the head unit for continuity supposedly the gray and gray and white stripe wire thing is if thats the problem why the heck would all my other speakers stop working ?
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
good luck with your fix, if you still cant figure it out, then i hope you have an ipod... lol... j/k
deaftosociety
its something to do with the rear door speakers now which i kinda find odd my dad opened the door half open and it started working then i started wiggling the door back and fourth n noticed it sounded like the connection was bad so were gona have to redo that apparently the speakers in the versa work as a continous circuit which is new for me compared to my trucks speakers lol now i can go back to bed get a few hours of sleep before work then try and handle this crap and go to it thanks for being the only one to reply skunk lol atleast you had something to somewhat try to cheer me up about this i thought i was gona have to send 600 dollars worth of car audio back lol
Knightro2
Car: 2008 Nissan Versa SL
Wow...zero punctuation in that post. lol
Sorry, just had to point that out. Atleast you found the issue. I did a stereo setup in my Bronco II and screwed something up. I didn't have sound for a month until I finally found what happened (an old speaker wire had been somehow severed that I couldn't see).
reyes1212
Car: '07 Nissan Versa Super Black
Go get it installed somewhere if you cant figure it out.
Kolk1
Car: 2007 Nissan Versa
Most head units have a built in protection circuit. if you have any type of short, or pinched wire, it will shut off sound to all speakers. Sounds like you isolated the problem. If its changing as you swing the door, check the wires going through the rubber boot into the B pillar.
deaftosociety
Knightro2 wrote:Wow...zero punctuation in that post. lol
sorry was in a rush... to go to sleep before work. these speakers are killer compared to the stock ones i donno how i managed to drive the car for as long as i did without these speakers... anyways just ignore this post lol i got it straightened out, now i just gota wait till i can get a good amp later after christmas to push these things the right way.
Return to “Versa Technical Discussions”
