Spark Plugs...
nab911
Car: 93 Nissan 240SX SE
Before the onslaught... I tried to search but the button was broken .
Now... my spark plugs are fowled again and this is the 3rd set so im going to upgrade this time. What are the part numbers for some plugs for a modified ca? T3 turbo, 460cc injectors and ~7lbs... The stockies arnt cuttin it.
PalmerWMD
Car: 2004 350Z
when you get them please be <sure> to support our sponros sparkplugs.com/denso.com http://www.sparkplugs.com/
Fred..
nab911
Wouldnt mind to... but what should i get?
zero_gripS13
Car: soon to be 95 s14 hopefully
http://www.sparkplugs.com/resu...12444
any of these..im guessing
iridium should last longer
nab911
Those will fit but will not work. I need turbo plugs, espciacialy with the amount of air and fuel im pumping in.
zero_gripS13
just get a colder heat range, and lower the gap..
i think the ngk iridiums 7 heat range gaped to 32-38 would be good
but wait till someone who has more expeirence can answer ur questions..
undertaker
Car: C33
zero_gripS13 wrote:just get a colder heat range, and lower the gap..
These should work well with these mods but if stock heat range plugs are fouling then colder plugs are likely to be worse, I suspect you are running too rich or the spark is too weak so decrease the gap and check your air/fuel ratios and timing.
nab911
Ok i know the air/fuel was fuctup because it wasnt tuned before. But after the ecu chipping and z32 maf they were already fouled and it was never run with the new tune. Do you guys have the part number for those plugs?
rico05
Car: 1992 RMS13 w/ CA18DET
"Other Spark Plug Options:PFR6/BCPR6's for standard (gap of 1.1mm)
PFR7/BCPR7's for lightly modded (gap of 0.8-10mm - see what works for you)
BCR8's for high boost applications. (gap 0.6-0.8 dependant on boost level)"
I run BCPR7E-11s myself. Gapped at .8mm and work great. But I have much less fuel and air than you (stock fuel save for Walbro and T25G @7psi).
float_6969
nab911 wrote:Ok i know the air/fuel was fuctup because it wasnt tuned before. But after the ecu chipping and z32 maf they were already fouled and it was never run with the new tune. Do you guys have the part number for those plugs?
Are you saying that they were fouled before you got it tuned for the mods that you have now? If you have an overfueling problem, changing sparkplugs isn't going to keep them from fouling. Also, what size turbo are you running? I seriously doubt you are going to need colder plugs unless you're making 250hp @ the flywheel.
float_6969
Nevermind, I see that you've got a T3 now. But at only 7psi, they still shouldn't be fouling.
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
running NGK double platinums in mine.. PFR6A-11 gapped to 0.8mm per plug.. even run at 16 pound and no tuning with bigger injectors and these things didn't blow out or get fuelled out.. pretty awesome plugs me thinks !! otherwise, the BCPR6E plugs work great too.. they are the stock NGK plugs, and they lasted ages at 13 pound, but that was with normal a/f mixtures, normal injectors the let.. still worked good !
Pete
nab911
Thank you guys! Im gonna run the double plats and see how well it turns out.
zero_gripS13
do not run platnum plugs in a turbocharged engine...
only iridium or copper...
platnum badbad
