piSSko »
https://forums.nicoclub.com/pissko-u255235.html
Fri Nov 11, 2016 9:53 am
Hi guys,
I'm over 140k and looking to change spark plugs. Have found it's gonna cost me approx. 115 CAD here in Toronto plus labor. Probably will do it myself.
Just to confirm, are the Denso FXE22HR11 iridium the best what I can get for my EX35 2009 or you have something else to suggest.
Not sure if the problem I'm having is related to bad plugs, but sometimes when the engine is worm up, after I start it, the RPMs will go to 1000 and then drop to the 200 and car will turn off. To have my car running, I would need to step little bit on the gas paddle to keep it ON. Also in idle it would work on 600 RPMs -is that normal?
Thanks!
