Spark Plug
mandoz85
I have a cross threaded spark plug hole. And it is causing my third sparkplug not to go all the way in. Now i have really bad idle. I there any way to fix the spark plug thread or will i have to get a new head.
I have a SOHC if that makes a ifference.Thanks
Structure240sx
that really sucks. i dont thin there are any taps that can go that deep. maybe if the head was pulled it could be retapped from the combustion chamber.
TrunkMonkey
Car: 2000 Lincoln Navigator
Structure240sx wrote:i dont thin there are any taps that can go that deep.
there is. iirc, i bought mine from napa. just make sure to use a strong shop vac to remove any excess shavings that may fall in the combustion chamber.
-demetrius
Structure240sx
good **** looks like u'll be ok. yea napa is a great place
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
you can get a tap and helicoil kit to repair. I have various heads with this done works well
mandoz85
Thank you, i went to napa and they have a 14mm and a 18mm thread chaser, which one would fit. i think it is the 14mm one.Thanks
Structure240sx
def not the 18mm. 14 seems about right im jsut tryin to think of it in my head. i know the spark plug is 16mm
