SuperTurbo »
https://forums.nicoclub.com/superturbo-u101956.html
Sat Aug 30, 2008 11:20 pm
I am not sure do you want to try this method..... Sounds retard, but sometimes it works.
Use a shop Vac to see did you get anything by vacuuming it.
Of course, you better make sure that cylinder is at top dead position, and remove some valve spring, so the valves are loose, then try to vacuum it, and see can you hear anything or get anything out.
