RubyRed300ZX »
https://forums.nicoclub.com/rubyred300zx-u159844.html
Sun Jun 28, 2015 8:51 am
My post above, the last line was kind of cryptic. Suggestion to check the air filter(s) was to say that if those are filthy then the previous owner wasn't very rigorous on routine maintenance. Thus, those plugs you pulled out have probably been in there for the full 60,000 miles, along with O2 sensors, PCV valves, belts and the timing belt, thermostat, water pump, coolant temp sensor, fuel temp sensor, Mass Airflow sensor etc.
